주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D630 Display Replacement
필요한 것
  1. Dell Latitude D630 Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Latitude D630 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Latitude D630 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 Display Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude D630 Display Replacement: 5 단계, 이미지 2개 중 2개
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 Display Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude D630 Display Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 Display Replacement, Display: 7 단계, 이미지 2개 중 1개 Dell Latitude D630 Display Replacement, Display: 7 단계, 이미지 2개 중 2개
    • Find and remove the display's ribbon cable by gently pulling on the blue tab indicated in the picture.
    • While tracing the path of the cable back to the display, unhook the cable from the tabs of the body using the spudger.
  8. Dell Latitude D630 Display Replacement: 8 단계, 이미지 2개 중 1개 Dell Latitude D630 Display Replacement: 8 단계, 이미지 2개 중 2개
    • Using the spudger, peel off the 6 circular rubber pads on the display to reveal the bezel screws beneath them. Put the rubber pads aside in a labeled container.
    • Careful: do not remove the two longer pads on the left and right side of the bezel; they do not contain any screws!
  9. Dell Latitude D630 Display Replacement: 9 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove each of the six screws (M2.5-5mm) on the bezel and put them in a labeled container.
  10. Dell Latitude D630 Display Replacement: 10 단계, 이미지 1개 중 1개
    • Using the spudger, slowly pry off the the bezel from the rest of the laptop. This can be done by placing the spludge in the small opening that separates the the two adjoining screen pieces along the edge. Slowly slide along this opening till the screen is free.
    • It's easiest to begin at the top (next to the laptop's latch) and make your way down on both sides.
  11. Dell Latitude D630 Display Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the 8 screws (M2-3mm) indicated in the picture. Place these screws in a labeled container as they are different than the bezel screws.
    • Do not remove these screws
    • If you are following this portion of the guide as a part of replacing the touchpad or the speaker, this step is NOT needed.
결론
To reassemble your device, follow these instructions in reverse order with your new display.
다른 23명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Jon Amireh
회원 가입일: 01/17/13
1,746 평판
안내서 8개를 작성함
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 회원
CPSU-JOHANN-W13S6G1
4 회원들
안내서 10개를 작성함
2가이드 댓글
Do I actually have to replace the entire monitor? Isnt there a way to use an external monitor?
Crysty N. Dela Cruz - 답글 공유
I really hope this works. This is the 3rd computer I bought in 3 weekz time. All 3 of tjem had something wrong. First the laptop had no hdd. Had to return that. 2nd, didnt evem turn on or have any power to it even after 24 hourz charge. And now this one, has something wrong witj tje monitor. A black screen. Yet, this one was surprise from my boyfriend. God, just make sure it works already.
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 113
전체 시간: 19,415
