주요 콘텐츠로 건너뛰기
Dell Latitude D630 Hard Drive Replacement
필요한 것
  1. Dell Latitude D630 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: 5 단계, 이미지 1/2 Dell Latitude D630 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Savi Chavan
회원 가입일: 03/12/14
979 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-4, Cichon Spring 2014 UMass Dartmouth, Team 1-4, Cichon Spring 2014 회원
UMASSD-CICHON-S14S1G4
3 회원들
안내서 1개 작성하였습니다
댓글 4개
Dell latitude 2RHczd1
C Chandler - 답글
I appreciate the guide my good sir. Very helpful.
Matt Erti - 답글
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 29
전체 시간: 15,330
