주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D630 Keyboard Replacement
필요한 것
  1. Dell Latitude D630 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Latitude D630 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Latitude D630 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude D630 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude D630 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jon Amireh
회원 가입일: 01/17/13
1,746 평판
안내서 8개를 작성함
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 회원
CPSU-JOHANN-W13S6G1
4 회원들
안내서 10개를 작성함
3가이드 댓글
These instructions were A+ fantastic! I have NEVER done any kind of computer dis-assembly OR re-assembly before. Your directions and pictures helped me feel confident from start to finish with a 100% success on the first try. I bought my son a Dell 630 to play Minecraft on and it needed a new keyboard, so THANK YOU, THANK YOU for making it possible for me do this so flawlessly. :-)
Tamara
Tamara - 답글 공유
Good job, easy to follow instructions without being over the top, good quality photos
Gordon McIntosh - 답글 공유
THIS I like !!! Finally, a series of shown steps that most anyone with brain can understand and do. My keyboard is worn out, there are wear holes in several keys.... yea, it is time to replace it and .... NOW WE CAN !
Warren
Warren Sjoberg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 94
전체 시간: 8,420
