소개
Introduction
Ram is your laptops temporary memory and can be replaced if damaged or you can upgrade it. This will help run more programs or make the ones you run faster and more efficient.
This Guide Will Teach You
- Where the ram is located
- How to remove safely
- Tools needed to complete the replacement
도구
부품
지정된 부품이 없습니다.
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
다른 13명이 해당 안내서를 완성하였습니다.
