소개
Removal and replacement of battery
필요한 것
Remove the charger from the laptop.
Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
If you are replacing other components, leave the battery out.
If you are only replacing the battery, reverse the steps to install a new battery.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
