주요 콘텐츠로 건너뛰기
Dell Latitude D820 Shuts Down For Unknown Cause.
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Dell Latitude D820 Shuts Down For Unknown Cause., Dust, Battery, Fan, Thermal Paste, GPU: 1 단계, 이미지 1/1
    • Dust acts like an insulator and contains moisture which can affect computer components if left over time.
    • Turn off computer and unplug AC adapter.
    • Use a can of compressed air to remove dust from vents, fan and power supply fan.
    • Removing dust should be considered routine maintenance and done on a regular basis.
  2. Dell Latitude D820 Shuts Down For Unknown Cause.: 2 단계, 이미지 1/1
    • Although a dead battery won't cause the laptop to overheat, it will cause it to shutdown unexpectedly.
    • Make sure battery connection is secure.
    • Make sure the Adapter is properly plugged into the wall and laptop.
    • Dell batteries come with a battery life indicator located on the bottom of the laptop. Press and release the test button. Each lights represent a 20% charge. If no lights are present, replacing the battery may be necessary.
    • Dell Latitude D820 Battery Replacement
  3. Dell Latitude D820 Shuts Down For Unknown Cause.: 3 단계, 이미지 1/1
    • If the fan is not working properly the laptop will overheat and shutdown.
    • Look to see if fan is spinning and dust free.
    • Go into Control Panel/ System/Device Manager/System Devices/and look for the fan. Right click on properties to see if the device is working properly.
    • Replace fan if necessary.
  4. Dell Latitude D820 Shuts Down For Unknown Cause.: 4 단계, 이미지 1/1
    • Blue Screen of Death (BSOD)
    • BIOS - out of date temperature table can cause heat issues.
    • Check the Dell website and download the latest BIOS. http://www.dell.com/support/home/us/en/1...
    • This photo has been modified to express generalized message on BSOD. The two lines *** are the ones that have been modified.
  5. Dell Latitude D820 Shuts Down For Unknown Cause., GPU Reflow: 5 단계, 이미지 1/1
    • If you've gotten here, you most likely have an issue with your GPU due to this recall: Dell Blog Post about NVIDIA GPU Recall
    • To fix this, you can try to "re-flow" the soldier on the motherboard, which should give you a little more life out of the laptop.
    • Follow this guide to remove your motherboard: D820 Motherboard Removal
    • Once you have remove the motherboard, clean off all of the thermal paste from the two remaining chips, one NVIDIA GPU, and another Intel.
    • Also remove all stickers, foam, and plastic from the motherboard, as they will melt or catch fire in the next step
    • Pre-heat your oven to 395 degrees Farenheight.
    • Place the motherboard on a sheet of foil, on a baking sheet. Place into the oven for 10 minutes. Then remove and let cool
    • Re-assemble laptop following motherboard steps in reverse.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Henry
회원 가입일: 09/02/14
1,431 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 회원
PHSC-PRINCE-F14S1G2
10 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,068
