주요 콘텐츠로 건너뛰기
Dell Latitude D830 Battery Replacement
필요한 것
  1. Dell Latitude D830 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the laptop so the opening is facing you.
  2. Dell Latitude D830 Battery Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over, so the opening is still facing you.
  3. Dell Latitude D830 Battery Replacement: 3 단계, 이미지 1/1
    • Place finger/ thumb on the slide button, then push the button forward
    • This unlocks the battery.
  4. Dell Latitude D830 Battery Replacement: 4 단계, 이미지 1/1
    • Place finger/thumb under the ledge.
  5. Dell Latitude D830 Battery Replacement: 5 단계, 이미지 1/1
    • Lift up the ledge, this allows the battery to be removed.
  6. Dell Latitude D830 Battery Replacement: 6 단계, 이미지 1/1
    • The battery is now removed.
  7. Dell Latitude D830 Battery Replacement: 7 단계, 이미지 1/1
    • To insert a new battery, orient the battery with the battery opening.
  8. Dell Latitude D830 Battery Replacement: 8 단계, 이미지 1/1
    • Insert the new battery with the left side being placed in first.
    • Press the new battery down until a "click" is heard.
결론
Nick Long
회원 가입일: 02/05/19
207 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 421
