주요 콘텐츠로 건너뛰기
Dell Latitude D830 RAM Replacement
필요한 것
  1. Dell Latitude D830 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Orient the laptop so that the back is facing you.
    • With a phillip's head screwdriver, remove the two screws on the back corners of the laptop.
  2. Dell Latitude D830 RAM Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over, with the opening still facing toward you.
    • With a phillip's head screwdriver remove the two screws in the upper two corners
  3. Dell Latitude D830 RAM Replacement: 3 단계, 이미지 1/1
    • Open the laptop up, displaying the keyboard and screen.
    • Take a spudger and insert it under the left edge of the panel located between the keyboard and screen.
    • Use the spudger to pry under the panel.
  4. Dell Latitude D830 RAM Replacement: 4 단계, 이미지 1/1
    • Place the spudger under the middle of the panel and use it to pry the panel off.
  5. Dell Latitude D830 RAM Replacement: 5 단계, 이미지 1/1
    • Place the spudger under the right side of the panel and use it to pry the panel off.
    • If additional help is needed place the spudger in various places around the edge of the panel.
  6. Dell Latitude D830 RAM Replacement: 6 단계, 이미지 1/1
    • After the panel has been popped off you must the pull the screen up as shown in the picture.
  7. Dell Latitude D830 RAM Replacement: 7 단계, 이미지 1/1
    • The screen will only be connected by the wiring.
    • Take the screen and gently lay it on the table as shown.
    • Now you must remove the three screws marked in the picture.
  8. Dell Latitude D830 RAM Replacement: 8 단계, 이미지 1/1
    • After removing the three screws, slide the keyboard out so the mainframe of it is loose.
    • There is still a component attached underneath.
  9. Dell Latitude D830 RAM Replacement: 9 단계, 이미지 1/1
    • The highlighted item should be the only component holding the keyboard.
  10. Dell Latitude D830 RAM Replacement: 10 단계, 이미지 1/3 Dell Latitude D830 RAM Replacement: 10 단계, 이미지 2/3 Dell Latitude D830 RAM Replacement: 10 단계, 이미지 3/3
    • Where the highlighted rectangle is, there is a silver lever that you must push back.
    • Then where the highlighted circle is, you must take a spudger and push in.
    • This will then pop the white clip off, and the keyboard will be completely free.
  11. Dell Latitude D830 RAM Replacement: 11 단계, 이미지 1/1
    • Once the keyboard has been removed you will see many of the circuit boards that lie underneath it.
    • The item highlighted is the RAM.
  12. Dell Latitude D830 RAM Replacement: 12 단계, 이미지 1/2 Dell Latitude D830 RAM Replacement: 12 단계, 이미지 2/2
    • The two clips highlighted are what hold the RAM in place.
    • Each of the clips should be pushed outward, freeing the RAM
    • The edge of the RAM that the arrow is pointing to should the be pulled, removing the RAM
  13. Dell Latitude D830 RAM Replacement: 13 단계, 이미지 1/1
    • The RAM is now removed.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 24
전체 시간: 443
