소개
This guide will be helpful to you if you are looking for information on how to remove the back panel. It is essential for accessing the laptop components located on the back side of the main board (ie. RAM and hard drive). Follow the steps in order for successful results.
필요한 것
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
