주요 콘텐츠로 건너뛰기
Dell Latitude E4200 Keyboard Replacement
필요한 것
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: 1 단계, 이미지 1/1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: 3 단계, 이미지 1/1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Latitude E4200 Keyboard Replacement: 5 단계, 이미지 2/2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: 6 단계, 이미지 1/1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: 7 단계, 이미지 1/1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: 8 단계, 이미지 1/1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: 9 단계, 이미지 1/1
    • Completely lift the keyboard from the device, as they are now disassembled.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Michelina Carbone
회원 가입일: 03/22/15
197 평판
안내서 1개 작성함
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 4,282
