소개
Follow these steps in order to successfully replace the SSD of your laptop.
필요한 것
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
You can use any mSATA SSD as replacement by using the following caddy/adapter:
jacques_06 - 답글
