주요 콘텐츠로 건너뛰기
Dell Latitude E4200 SSD Replacement
필요한 것
  1. Dell Latitude E4200 SSD Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: 2 단계, 이미지 1/3 Dell Latitude E4200 SSD Replacement: 2 단계, 이미지 2/3 Dell Latitude E4200 SSD Replacement: 2 단계, 이미지 3/3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: 3 단계, 이미지 1/1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: 4 단계, 이미지 1/1
    • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
  5. Dell Latitude E4200 SSD Replacement: 5 단계, 이미지 1/1
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: 6 단계, 이미지 1/1
    • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
결론
다른 6명이 해당 안내서를 완성하였습니다.
John Shellenberger
회원 가입일: 03/23/15
490 평판
안내서 3개 작성하였습니다
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G6
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/166263029472
jacques_06 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 16
전체 시간: 8,319
