주요 콘텐츠로 건너뛰기
소개
The keyboard docking component is the middle panel located between the keyboard and the internal components of the laptop. In order to replace components within the laptop , such as the motherboard, you will need to remove the panel. Use this guide for a step-by-step procedure.
부품
지정된 부품이 없습니다.
  1. Open the laptop and remove the small panel located above the keyboard.
    • Open the laptop and remove the small panel located above the keyboard.
  2. Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Pull off keyboard forward and then outwards.
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  5. Remove additional wires located within the panel. For the smaller wires, try using a spudger for easier access.
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  6. Lift the keyboard panel to separate the component from the rest of the device.
    • Lift the keyboard panel to separate the component from the rest of the device.
결론
Ryan Blakey
회원 가입일: 2018년 09월 24일
172 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 64
