주요 콘텐츠로 건너뛰기
Dell Latitude E4300 Keyboard Replacement
필요한 것
  1. Dell Latitude E4300 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Keyboard Replacement: 2 단계, 이미지 1/1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Keyboard Replacement: 3 단계, 이미지 1/1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
결론
Maritza Martinez
회원 가입일: 09/21/18
324 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 9
전체 시간: 644
