필요한 것
Close the display and turn the computer upside-down.
Loosen the captive screws on the memory cover.
Remove the memory cover.
Use your fingertips to carefully spread apart the retaining clips on each end of the memory module connector until the module pops up.
Remove the module by grasping it at the side edges and pulling it away from the connector. Place the module into anti-static packaging such as an anti-static bag.
Remove the memory module from its anti-static packaging.
Grasping the module at the side edges, align the slot in the module edge connector with the key in the socket connector.
Slide the memory module into the socket connector at a 30-degree angle until it is fully seated.
Push the long edge of the memory module down until the retaining clips lock the module into place.
Replace the memory cover and tighten the captive screws.
