주요 콘텐츠로 건너뛰기
Dell Latitude E4310 Display Replacement
필요한 것
  1. Dell Latitude E4310 Display Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: 2 단계, 이미지 1/2 Dell Latitude E4310 Display Replacement: 2 단계, 이미지 2/2
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: 3 단계, 이미지 1/3 Dell Latitude E4310 Display Replacement, Display: 3 단계, 이미지 2/3 Dell Latitude E4310 Display Replacement, Display: 3 단계, 이미지 3/3
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: 4 단계, 이미지 1/2 Dell Latitude E4310 Display Replacement: 4 단계, 이미지 2/2
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: 5 단계, 이미지 1/2 Dell Latitude E4310 Display Replacement: 5 단계, 이미지 2/2
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: 6 단계, 이미지 1/2 Dell Latitude E4310 Display Replacement: 6 단계, 이미지 2/2
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: 7 단계, 이미지 1/3 Dell Latitude E4310 Display Replacement: 7 단계, 이미지 2/3 Dell Latitude E4310 Display Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: 8 단계, 이미지 1/1
    • Remove the screen from the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aylin
회원 가입일: 02/21/18
285 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,529
