주요 콘텐츠로 건너뛰기
Dell Latitude E5410 keyboard Replacement
필요한 것
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: 1 단계, 이미지 1/1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: 2 단계, 이미지 1/1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: 3 단계, 이미지 1/1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: 4 단계, 이미지 1/1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Megan Perrizo
회원 가입일: 09/29/16
377 평판
안내서 2개 작성하였습니다
댓글 한 개
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 22
전체 시간: 5,117
