주요 콘텐츠로 건너뛰기
Dell Latitude E5430 Hard Drive Replacement
필요한 것
  1. Dell Latitude E5430 Hard Drive Replacement, Remove the Battery: 1 단계, 이미지 1/1
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Dell Latitude E5430 Hard Drive Replacement, Remove the Bottom Cover: 2 단계, 이미지 1/1
    • Remove two Phillips head screws from the bottom cover.
  3. Dell Latitude E5430 Hard Drive Replacement, Remove the Hard Drive Caddy: 3 단계, 이미지 1/1
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  4. Dell Latitude E5430 Hard Drive Replacement, Unscrew the Hard Drive from the Caddy: 4 단계, 이미지 1/1
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  5. Dell Latitude E5430 Hard Drive Replacement, Done!: 5 단계, 이미지 1/1
    • Congratulations, you've done it!
결론
After you have installed your new hard drive or SSD, repeat the process in reverse.
다른 5명이 해당 안내서를 완성하였습니다.
Sam
회원 가입일: 02/24/17
648 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 33
전체 시간: 3,612
