이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will demonstrate how to replace the hard drive on your Latitude E5430.
필요한 것
Remove the four Phillips head screws from the hard drive caddy.
System memory (RAM) is located here.
Low profile WLAN card
Remove the four Phillips head screws surrounding the hard drive in the caddy.
After you have installed your new hard drive or SSD, repeat the process in reverse.
다른 5명이 해당 안내서를 완성하였습니다.
