주요 콘텐츠로 건너뛰기
Dell Latitude E5470 Battery Replacement
필요한 것
  1. Dell Latitude E5470 Battery Replacement, Removing the Battery: 1 단계, 이미지 1/1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift the battery away from the computer [3].
  2. Dell Latitude E5470 Battery Replacement, Remove the cable from the battery: 2 단계, 이미지 1/1
    • Unroute the cable from the routing channel [1] and remove the cable from the battery [2].
    • Connect the battery cable to the connector on the battery.
    • Route the battery cable through the routing channel on the battery
    • Insert the battery into the slot on the computer.
    • Tighten the screws to secure the battery to the computer.
    • Connect the battery cable to the connector on the system board
결론
Marvin Romero
회원 가입일: 03/18/21
3,736 평판
안내서 32개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 25
전체 시간: 607
