주요 콘텐츠로 건너뛰기
Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly)
필요한 것
  1. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: 1 단계, 이미지 2개 중 1개 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: 1 단계, 이미지 2개 중 2개
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Disconnect the battery: 2 단계, 이미지 1개 중 1개
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Bezel: 3 단계, 이미지 1개 중 1개
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Removing the LCD panel: 4 단계, 이미지 1개 중 1개
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: 5 단계, 이미지 3개 중 1개 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: 5 단계, 이미지 3개 중 2개 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Harvey
회원 가입일: 02/15/16
5,820 평판
안내서 10개를 작성함
댓글 5개
Your presentation is perfect
sachida1986niit - 답글
Thanks very much :)
Harvey - 답글
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - 답글
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 8,909
