주요 콘텐츠로 건너뛰기
Dell Latitude E5500 Cooling Fan Replacement
필요한 것
  1. Dell Latitude E5500 Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Cooling Fan Replacement: 2 단계, 이미지 1/2 Dell Latitude E5500 Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Cooling Fan Replacement: 3 단계, 이미지 1/1
    • The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
  4. Dell Latitude E5500 Cooling Fan Replacement: 4 단계, 이미지 1/3 Dell Latitude E5500 Cooling Fan Replacement: 4 단계, 이미지 2/3 Dell Latitude E5500 Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
    • Disconnect the fan header from the motherboard of the laptop.
    • The fan header has many small wires sleeved together. To avoid ripping the wires out of the connector, wiggle the connector out of place instead of pulling straight up on it.
  5. Dell Latitude E5500 Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Remove the fan from its housing.
    • The fan may be difficult to get out of the housing, as it is surrounded on three sides by the housing itself and the heatsink. It is not glued or taped in, however, so you can gently pull the cord you just disconnected up to remove the fan from the housing without risk of damaging the cord.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Richard Harrison
회원 가입일: 10/23/16
805 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 20
전체 시간: 1,550
