주요 콘텐츠로 건너뛰기
Dell Latitude E5500 RAM Replacement
필요한 것
  1. Dell Latitude E5500 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: 2 단계, 이미지 1/2 Dell Latitude E5500 RAM Replacement: 2 단계, 이미지 2/2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: 3 단계, 이미지 1/1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: 4 단계, 이미지 1/2 Dell Latitude E5500 RAM Replacement: 4 단계, 이미지 2/2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: 5 단계, 이미지 1/3 Dell Latitude E5500 RAM Replacement: 5 단계, 이미지 2/3 Dell Latitude E5500 RAM Replacement: 5 단계, 이미지 3/3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
결론
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Evan Eldridge
회원 가입일: 10/20/16
215 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 2,065
