주요 콘텐츠로 건너뛰기
Dell Latitude E5500 Wireless Card Replacement
필요한 것
  1. Dell Latitude E5500 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Wireless Card Replacement: 2 단계, 이미지 1/2 Dell Latitude E5500 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Wireless Card Replacement: 3 단계, 이미지 1/2 Dell Latitude E5500 Wireless Card Replacement: 3 단계, 이미지 2/2
    • The wireless card is located near the front of the device, and is the expansion card with three antennas attached to it.
  4. Dell Latitude E5500 Wireless Card Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the wires connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Wireless Card Replacement: 5 단계, 이미지 1/1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Wireless Card Replacement: 6 단계, 이미지 1/2 Dell Latitude E5500 Wireless Card Replacement: 6 단계, 이미지 2/2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Richard Harrison
회원 가입일: 10/23/16
796 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,203
