주요 콘텐츠로 건너뛰기
Dell Latitude E5550-5550 Battery Replacement
필요한 것
  1. Dell Latitude E5550-5550 Battery Replacement, Remove Cover: 1 단계, 이미지 1/1
    • -Remove the sides on the back of the computer to take off the cover for the battery.
  2. Dell Latitude E5550-5550 Battery Replacement, Remove the battery: 2 단계, 이미지 1/1
    • Disconnect battery cable from the connector and release cable from its routing channel.
  3. Dell Latitude E5550-5550 Battery Replacement, Screw removal: 3 단계, 이미지 1/1
    • Remove the screw that secures the battery and lift and push to remove the battery from the computer.
    • -Insert the battery into its place on the computer.
    • Route the battery cable through its routing channel.
    • Tighten the screw to secure the battery to the computer.
    • Connect the battery cable to its connector on the system board.
    • Install the base cover.
    • Connect your computer and all attached devices to their electrical outlets.
    • Turn on your computer.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jaden Graham
회원 가입일: 02/10/21
211 평판
안내서 1개 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 23
전체 시간: 907
