이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the two latches each side of the battery outwards. You'll notice you've unlatched the battery from the chassis when you hear two clicks.
To remove the battery from the chassis, pull it up from underneath the top of the battery.
Place the battery on a sensible surface, where it won't fall down.
Remove the four Phillips #00 screws that secure the hard drive to the computer.
Find the outdent at the right side of the chassis, and pull it outward to release and slide out the hard drive.
Remove the Phillips #00 screw that secures the drive caddy to the hard drive.
Dislodge the caddy from the drive by lifting the caddy up and wiggling it outwards at the same time.
다른 한 분이 해당 안내서를 완성하였습니다.
