주요 콘텐츠로 건너뛰기
Dell Latitude E6400 Hard Drive Replacement
필요한 것
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive: 5 단계, 이미지 1/1
    • After removing the battery, locate and remove the two M3 x 3-mm screws securing the hard drive to the base assembly. Then, slide the hard drive from the base assembly.
  4. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive bezel: 6 단계, 이미지 1/1
    • Next, remove the M3 x 3-mm screw on the hard drive bezel and remove the hard drive bezel. NOTE: Be mindful not to touch the components of the drive. Doing so could damage the drive.
결론
With your replacement hard drive, reassemble your device by performing the instructions above in reverse order.
Aaron Thomas
회원 가입일: 02/16/21
1,194 평판
안내서 10개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
Easy hard drive replacement!
Jeffrey P - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 47
전체 시간: 1,284
