주요 콘텐츠로 건너뛰기
Dell Latitude E6400 WiFi Card Replacement
필요한 것
  1. Dell Latitude E6400 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 2/2
    • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
    • This will release the battery. Just slide the battery away from the computer.
    • Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
    • This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
  2. Dell Latitude E6400 WiFi Card Replacement: 2 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement: 2 단계, 이미지 2/2
    • Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
    • It can't be removed as it is captive the the bottom plate.
    • Now slide the plate away from the dock connector.
  3. Dell Latitude E6400 WiFi Card Replacement: 3 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool or a spudger to remove the antennas.
    • I use my fingers, but the picture shows and iPod opening tool because most adults have bigger fingers.
    • I'm 14, so my fingers are small enough.
    • Some E6400 models have a card with three connections-a gray wire in the middle-marked appropriately.
  4. Dell Latitude E6400 WiFi Card Replacement: 4 단계, 이미지 1/1
    • remove the one and only philips screw securing the WiFi card in place.
  5. Dell Latitude E6400 WiFi Card Replacement: 5 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement: 5 단계, 이미지 2/2
    • The card should instantly pop to an angle less than 45 degrees once the screw is removed.
    • Now simply pull the card strait away from the slot.
    • Install a new card by sliding it in the direction of the arrow and pressing firmly down until it clicks.
  6. Dell Latitude E6400 WiFi Card Replacement: 6 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement: 6 단계, 이미지 2/2
    • Slide the bottom plate on.
    • Slide it to the rear of the notebook. (battery compartment)
    • Tighten the screw.
    • Do not over-tighten. Doing so will strip the screw.
  7. Dell Latitude E6400 WiFi Card Replacement: 7 단계, 이미지 1/2 Dell Latitude E6400 WiFi Card Replacement: 7 단계, 이미지 2/2
    • Slide the battery in until it clicks.
    • Press the power button.
    • AND it works.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Nicholas Ouimet
회원 가입일: 10/16/09
3,479 평판
안내서 12개 작성하였습니다
댓글 한 개
Why is your soundcloud linked as the wifi card site. It is really not appropriate considering how great of a job you did with the instructions for this repair.
Sean Brewer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 37
전체 시간: 28,478
