소개
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
필요한 것
Push the tabs on the left and right of the battery out towards the edge of the case.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
다른 4명이 해당 안내서를 완성하였습니다.
