주요 콘텐츠로 건너뛰기
Dell Latitude E6420 Keyboard Replacement
필요한 것
  1. Dell Latitude E6420 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Keyboard Replacement: 2 단계, 이미지 1/1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: 3 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: 3 단계, 이미지 2/2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement: 4 단계, 이미지 2/2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Keyboard Replacement, Backplate: 5 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement, Backplate: 5 단계, 이미지 2/2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement: 6 단계, 이미지 2/2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Keyboard Replacement, Keyboard: 7 단계, 이미지 1/3 Dell Latitude E6420 Keyboard Replacement, Keyboard: 7 단계, 이미지 2/3 Dell Latitude E6420 Keyboard Replacement, Keyboard: 7 단계, 이미지 3/3
    • Use the plastic opening tool to remove the bezel from around the keyboard.
  8. Dell Latitude E6420 Keyboard Replacement: 8 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement: 8 단계, 이미지 2/2
    • Using the screwdriver, remove four 3mm Phillips #0 screws from the keyboard.
  9. Dell Latitude E6420 Keyboard Replacement: 9 단계, 이미지 1/2 Dell Latitude E6420 Keyboard Replacement: 9 단계, 이미지 2/2
    • Lift the keyboard and use the spudger to disconnect the keyboard cable.
    • Gently lift the keyboard to prevent damage to the cable.
  10. Dell Latitude E6420 Keyboard Replacement: 10 단계, 이미지 1/1
    • Lift the keyboard out of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Madysen Eames
회원 가입일: 02/27/18
1,528 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 UMass Dartmouth, Team S2-G3, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 35
전체 시간: 3,289
