주요 콘텐츠로 건너뛰기
Dell Latitude E6420 Screen Replacement
필요한 것
  1. Dell Latitude E6420 Screen Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude E6420 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: 2 단계, 이미지 1/1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: 3 단계, 이미지 1/2 Dell Latitude E6420 Screen Replacement, Screen: 3 단계, 이미지 2/2
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: 4 단계, 이미지 1/3 Dell Latitude E6420 Screen Replacement: 4 단계, 이미지 2/3 Dell Latitude E6420 Screen Replacement: 4 단계, 이미지 3/3
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: 5 단계, 이미지 1/1
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: 6 단계, 이미지 1/2 Dell Latitude E6420 Screen Replacement: 6 단계, 이미지 2/2
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: 7 단계, 이미지 1/2 Dell Latitude E6420 Screen Replacement: 7 단계, 이미지 2/2
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Madysen Eames
회원 가입일: 02/27/18
1,528 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 UMass Dartmouth, Team S2-G3, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Bonjour, Merci
endibos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 37
전체 시간: 3,950
