주요 콘텐츠로 건너뛰기
Dell Latitude E6510 Heat Sink Replacement
필요한 것
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 1 단계, 이미지 1/3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 1 단계, 이미지 2/3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 1 단계, 이미지 3/3
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: 2 단계, 이미지 1/3 Dell Latitude E6510  Heat Sink Replacement: 2 단계, 이미지 2/3 Dell Latitude E6510  Heat Sink Replacement: 2 단계, 이미지 3/3
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: 3 단계, 이미지 1/3 Dell Latitude E6510  Heat Sink Replacement: 3 단계, 이미지 2/3 Dell Latitude E6510  Heat Sink Replacement: 3 단계, 이미지 3/3
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: 4 단계, 이미지 1/3 Dell Latitude E6510  Heat Sink Replacement: 4 단계, 이미지 2/3 Dell Latitude E6510  Heat Sink Replacement: 4 단계, 이미지 3/3
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: 5 단계, 이미지 1/1
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: 6 단계, 이미지 1/3 Dell Latitude E6510  Heat Sink Replacement: 6 단계, 이미지 2/3 Dell Latitude E6510  Heat Sink Replacement: 6 단계, 이미지 3/3
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Noah
회원 가입일: 02/05/19
327 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 925
