주요 콘텐츠로 건너뛰기
Dell Latitude E6510 USB Ports Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell Latitude E6510  USB Ports Replacement, Fan: 1 단계, 이미지 1/2 Dell Latitude E6510  USB Ports Replacement, Fan: 1 단계, 이미지 2/2
    • Slide the two black clips toward the middle to release battery
  2. Dell Latitude E6510  USB Ports Replacement: 2 단계, 이미지 1/2 Dell Latitude E6510  USB Ports Replacement: 2 단계, 이미지 2/2
    • Remove the back plate from the back of the device
    • Remove the 6 screws with the J1 screwdriver.
    • once the screws are out, slide back panel towards front of the device and lift up
  3. Dell Latitude E6510  USB Ports Replacement: 3 단계, 이미지 1/3 Dell Latitude E6510  USB Ports Replacement: 3 단계, 이미지 2/3 Dell Latitude E6510  USB Ports Replacement: 3 단계, 이미지 3/3
    • Remove two screws holding the fan
    • Slide from under copper heat sink
    • Unplug connector and remove
    • To reassemble, follow directions in reverse
  4. Dell Latitude E6510  USB Ports Replacement, USB Ports: 4 단계, 이미지 1/2 Dell Latitude E6510  USB Ports Replacement, USB Ports: 4 단계, 이미지 2/2
    • Remove the battery
    • Flip the computer so that it is facing downward.
    • Next locate the two black clips as shown in the image.
    • Slide the clips toward the middle in order to release the battery.
  5. Dell Latitude E6510  USB Ports Replacement: 5 단계, 이미지 1/3 Dell Latitude E6510  USB Ports Replacement: 5 단계, 이미지 2/3 Dell Latitude E6510  USB Ports Replacement: 5 단계, 이미지 3/3
    • Remove the back plate from the back of the device.
    • Using the Philips head screwdriver remove the 6 screws marked in red.
    • Next, slide the panel down and then lift up til completely removed.
  6. Dell Latitude E6510  USB Ports Replacement: 6 단계, 이미지 1/3 Dell Latitude E6510  USB Ports Replacement: 6 단계, 이미지 2/3 Dell Latitude E6510  USB Ports Replacement: 6 단계, 이미지 3/3
    • Press the button on the side of the optical drive in order to release the pull tab.
    • Next, pull out the optical drive located on the lower left hand side.
    • Locate the hard drive on the lower right hand side and remove it from the computer.
  7. Dell Latitude E6510  USB Ports Replacement: 7 단계, 이미지 1/3 Dell Latitude E6510  USB Ports Replacement: 7 단계, 이미지 2/3 Dell Latitude E6510  USB Ports Replacement: 7 단계, 이미지 3/3
    • Using the Philips head screwdriver unscrew the two screws holding the fan.
    • Next, slide the fan out from under the copper heat sink.
    • Unplug the connector marked in blue and remove the fan.
  8. Dell Latitude E6510  USB Ports Replacement: 8 단계, 이미지 1/2 Dell Latitude E6510  USB Ports Replacement: 8 단계, 이미지 2/2
    • Using the Philips head screwdriver unscrew the seven screws holding down the copper heat sink.
    • Lift the heat sink slightly and slide out to remove it.
  9. Dell Latitude E6510  USB Ports Replacement: 9 단계, 이미지 1/3 Dell Latitude E6510  USB Ports Replacement: 9 단계, 이미지 2/3 Dell Latitude E6510  USB Ports Replacement: 9 단계, 이미지 3/3
    • Using a spudger remove the volume bar above the keyboard
    • Using the Philips head screwdriver unscrew the two screws near the top of the keyboard.
    • Lift the keyboard membrane slightly by tab, and slide the keyboard towards the screen in order to remove.
    • Using the Philips head screwdriver unscrew the three screws marked in green.
  10. Dell Latitude E6510  USB Ports Replacement: 10 단계, 이미지 1/1
    • Using the Philip head screwdriver unscrew the eight screws holding down the chassis to get to the USB ports.
  11. Dell Latitude E6510  USB Ports Replacement: 11 단계, 이미지 1/1
    • Remove the USB port by using a soldering iron to take out the connections on either side of the port.
결론
Ronald Denardo
회원 가입일: 02/05/19
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 1,364
