주요 콘텐츠로 건너뛰기
Dell Latitude E6510 Fan Replacement
필요한 것
  1. Dell Latitude E6510 Fan Replacement, Fan: 1 단계, 이미지 1/3 Dell Latitude E6510 Fan Replacement, Fan: 1 단계, 이미지 2/3 Dell Latitude E6510 Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Remove the battery.
    • Remove the five strews that are holding the back cover down.
    • Firmly grasp the laptop and slide the cover to the front, then lift.
  2. Dell Latitude E6510 Fan Replacement: 2 단계, 이미지 1/3 Dell Latitude E6510 Fan Replacement: 2 단계, 이미지 2/3 Dell Latitude E6510 Fan Replacement: 2 단계, 이미지 3/3
    • Unscrew the 7 gray screws.
    • They will not disconnect from the gray plates.
    • Remove the 2 black screws that hold the fan in place.
  3. Dell Latitude E6510 Fan Replacement: 3 단계, 이미지 1/1
    • Wiggle the fan in the direction of the arrows until the end of the fan comes out.
  4. Dell Latitude E6510 Fan Replacement: 4 단계, 이미지 1/1
    • Pick up and pull the heat sink out in the direction of the arrow.
  5. Dell Latitude E6510 Fan Replacement: 5 단계, 이미지 1/2 Dell Latitude E6510 Fan Replacement: 5 단계, 이미지 2/2
    • Firmly grasp the fan cord close to the plug, and pull straight up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 10
전체 시간: 1,786
