소개
If you need to reinstall a new LCD screen, access the screen with this guide. For this guide, you will need a Phillips #0 screwdriver head. You will not need to do any difficult steps, but unscrew screws, and detach wires.
도구
부품
지정된 부품이 없습니다.
Orient your laptop so that the bottom is facing up towards you.
Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
Slide the battery out and separate it from the laptop.
Take the silver panels from both sides of the back of the laptop by removing the screw using a type 0 Philips head.
Slide the silver panel away from you to revel some wires.
Remove the two wires white and gray by gently pulling up and detaching them.
After the wires are detached, gently pull the wires away from you to remove them from the groove they are in.
Under the ride silver panel, there is a channel. To disconnect gently use your nail and flick it up and to the right.
Once the channel is disconnect, there are two wires. Repeat the same method as the channel to disconnect the wires.
Move the channel and wires out of the groove to remove the screen.
다른 2명이 해당 안내서를 완성하였습니다.
