이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Orient your laptop so that the bottom is facing up towards you.
Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
Slide the battery out and separate it from the laptop.
Remove the 5 screws from the back panel with a type 0 Philips head.
Then pull the panel towards you in a slightly upwards motion.
Separate the panel from the laptop.
Take the silver panels from both sides of the back of the laptop by removing the screw using a type 0 Philips head.
Slide the silver panel away from you to revel some wires.
Remove the two wires white and gray by gently pulling up and detaching them.
After the wires are detached, gently pull the wires away from you to remove them from the groove they are in.
Under the ride silver panel, there is a channel. To disconnect gently use your nail and flick it up and to the right.
Once the channel is disconnect, there are two wires. Repeat the same method as the channel to disconnect the wires.
Move the channel and wires out of the groove to remove the screen.
Orient the laptop on its side, prop it slightly open to keep it stable on your desk.
Unscrew the silver screw on the left side using a type 0 Phillip's head.
Unscrew the black screw on the right side using a type 0 Philips head.
Since the screws and wires are disconnect, the screen is ready to be disconnected also.
Gently hold the LCD screen with your pointer fingers on either side.
While firmly holding the bottom of the laptop with your thumbs pull the two parts away from each other.
다른 3명이 해당 안내서를 완성하였습니다.
