주요 콘텐츠로 건너뛰기
Dell Latitude E6510 RAM Replacement
필요한 것
  1. Dell Latitude E6510 RAM Replacement, RAM: 1 단계, 이미지 1/3 Dell Latitude E6510 RAM Replacement, RAM: 1 단계, 이미지 2/3 Dell Latitude E6510 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Orient the laptop so that the bottom is facing up towards you.
    • Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
    • Slide the battery out and separate it from the laptop.
  2. Dell Latitude E6510 RAM Replacement: 2 단계, 이미지 1/3 Dell Latitude E6510 RAM Replacement: 2 단계, 이미지 2/3 Dell Latitude E6510 RAM Replacement: 2 단계, 이미지 3/3
    • Remove the 5 screws from the back panel with a type 0 Phillips head.
    • Pull the panel towards you in a slightly upwards motion.
    • Remove the panel from the laptop and set it aside.
  3. Dell Latitude E6510 RAM Replacement: 3 단계, 이미지 1/3 Dell Latitude E6510 RAM Replacement: 3 단계, 이미지 2/3 Dell Latitude E6510 RAM Replacement: 3 단계, 이미지 3/3
    • Locate the RAM sticks in the laptop.
    • Using your fingers, disconnect the prongs connected to the RAM sticks.
    • Gently remove the RAM from the port.
    • Repeat the first three steps to remove the second RAM stick.
결론
Seth Thomas
회원 가입일: 02/05/19
112 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 213
