주요 콘텐츠로 건너뛰기
Dell Latitude E6510 Speaker Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell Latitude E6510 Speaker Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement, Keyboard: 1 단계, 이미지 3/3
    • Open the laptop and locate the volume panel on the keyboard.
    • Use the spudger to get underneath the righthand side of the panel and gently pry up the side.
  2. Dell Latitude E6510 Speaker Replacement: 2 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 2 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the detached volume panel from the keyboard.
    • Locate the two screws holding the keyboard in place. Then Remove these screws with a Philips PH1 head screwdriver.
  3. Dell Latitude E6510 Speaker Replacement: 3 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 3 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 3 단계, 이미지 3/3
    • Locate the tab near the back of the keyboard.
    • Pull upwards on the tab to start removing the keyboard and then using both hands at the sides, pull until the keyboard comes free.
  4. 주의: 4-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell Latitude E6510 Speaker Replacement, Battery: 4 단계, 이미지 1/1
    • Make sure the device is shutdown
    • Position the laptop upside down with the battery facing towards you.
    • Locate the battery latches circled in red.
  5. Dell Latitude E6510 Speaker Replacement: 5 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 5 단계, 이미지 2/2
    • Gently slide both latches inward until you hear both latches release.
  6. Dell Latitude E6510 Speaker Replacement: 6 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 6 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 6 단계, 이미지 3/3
    • Pull the battery towards yourself as shown until completely removed from the computer.
  7. 주의: 7-11 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell Latitude E6510 Speaker Replacement, Fan: 7 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement, Fan: 7 단계, 이미지 2/2
    • Flip over laptop and locate door panel screws.
    • Remove the Screws.
  8. Dell Latitude E6510 Speaker Replacement: 8 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 8 단계, 이미지 2/2
    • Slide and remove the access door.
  9. Dell Latitude E6510 Speaker Replacement: 9 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 9 단계, 이미지 2/2
    • Locate the fan and two fan screws.
    • Remove the 2 screws using a PZ0 Phillip head screwdriver.
  10. Dell Latitude E6510 Speaker Replacement: 10 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 10 단계, 이미지 2/2
    • Using a plastic spudger, gently pry the fan upwards.
    • Once the fan has been loosened, slowly remove the main fan component.
    • Do not pull too hard as their is still a wire attached.
  11. Dell Latitude E6510 Speaker Replacement: 11 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 11 단계, 이미지 2/2
    • Locate the wire holding the fan in place and detach the clip.
  12. Dell Latitude E6510 Speaker Replacement, Speaker: 12 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement, Speaker: 12 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement, Speaker: 12 단계, 이미지 3/3
    • Remove the hard drive.
    • Pull the drive right and out of the computer.
  13. Dell Latitude E6510 Speaker Replacement: 13 단계, 이미지 1/1
    • Remove the small battery.
    • Undo the blue circle first.
    • Pull out the end of the cord by the plastic part to avoid damage to the wire.
  14. Dell Latitude E6510 Speaker Replacement: 14 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 14 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 14 단계, 이미지 3/3
    • Loosen but do not remove the silver screws surrounding the heat sink using a PZ1 screwhead.
  15. Dell Latitude E6510 Speaker Replacement: 15 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 15 단계, 이미지 2/2
    • Remove the heat sink from the laptop.
  16. Dell Latitude E6510 Speaker Replacement: 16 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 16 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 16 단계, 이미지 3/3
    • Push the silver clips on both sides of the memory cards outwards.
    • Gently pull the cards out one at a time.
  17. Dell Latitude E6510 Speaker Replacement: 17 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 17 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 17 단계, 이미지 3/3
    • Unscrew the side panels on both sides and slide them off.
  18. Dell Latitude E6510 Speaker Replacement: 18 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 18 단계, 이미지 2/2
    • Remove the screws of the back framework.
  19. Dell Latitude E6510 Speaker Replacement: 19 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 19 단계, 이미지 2/2
    • Loosen the two highlighted screws, do not remove.
  20. Dell Latitude E6510 Speaker Replacement: 20 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 20 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 20 단계, 이미지 3/3
    • Undo the cables until the are not attached to the back half of the keyboard.
    • Pull the cables backwards and to the side of the laptop.
  21. Dell Latitude E6510 Speaker Replacement: 21 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 21 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 21 단계, 이미지 3/3
    • Undo the other side also.
    • The cables should only be loose, not removed.
  22. Dell Latitude E6510 Speaker Replacement: 22 단계, 이미지 1/2 Dell Latitude E6510 Speaker Replacement: 22 단계, 이미지 2/2
    • Partially open the laptop.
    • Side the top half of the laptop backwards towards yourself to undo it from the bottom half.
  23. Dell Latitude E6510 Speaker Replacement: 23 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 23 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 23 단계, 이미지 3/3
    • Pry the frame work of the laptop off using a plastic splunger.
    • Proceed slowly, any screws that may have been missed can break your laptop if not removed.
  24. Dell Latitude E6510 Speaker Replacement: 24 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 24 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 24 단계, 이미지 3/3
    • Remove the screws from the wireless detector.
    • Remove the detector.
  25. Dell Latitude E6510 Speaker Replacement: 25 단계, 이미지 1/3 Dell Latitude E6510 Speaker Replacement: 25 단계, 이미지 2/3 Dell Latitude E6510 Speaker Replacement: 25 단계, 이미지 3/3
    • Remove the screws from the top and bottom of both speakers.
    • Remove the speakers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 2,744
