소개
As a quick warning before you dive into replacing your speakers, this will be a long, hard task. By the time you will even see the speakers the laptop will be completely taken apart. Make sure to not lose your screws and ensure you have plenty of time and space before you follow this guide.
필요한 것
1 단계 Keyboard
주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Open the laptop and locate the volume panel on the keyboard.
Use the spudger to get underneath the righthand side of the panel and gently pry up the side.
4 단계 Battery
주의: 4-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Position the laptop upside down with the battery facing towards you.
Locate the battery latches circled in red.
다른 한 분이 해당 안내서를 완성하였습니다.
