소개
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
필요한 것
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
