주요 콘텐츠로 건너뛰기
Dell Latitude E6520 WLAN Adaptor Card Replacement
필요한 것
  1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: 1 단계, 이미지 2/2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 WLAN Adaptor Card Replacement: 2 단계, 이미지 1/2 Dell Latitude E6520 WLAN Adaptor Card Replacement: 2 단계, 이미지 2/2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: 3 단계, 이미지 1/2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 WLAN Adaptor Card Replacement: 4 단계, 이미지 1/1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 WLAN Adaptor Card Replacement, WLAN Adapter Card: 5 단계, 이미지 1/1
    • Gently pull the two wires connected to the WLAN Adapter Card.
  6. Dell Latitude E6520 WLAN Adaptor Card Replacement: 6 단계, 이미지 1/2 Dell Latitude E6520 WLAN Adaptor Card Replacement: 6 단계, 이미지 2/2
    • Remove the two electrode connectors.
    • Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • The WLAN Adapter Card will pop up once the screws are taken out.
  7. Dell Latitude E6520 WLAN Adaptor Card Replacement: 7 단계, 이미지 1/2 Dell Latitude E6520 WLAN Adaptor Card Replacement: 7 단계, 이미지 2/2
    • Pull WLAN Adapter Card to remove it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alec Weiss
회원 가입일: 11/05/18
800 평판
안내서 8개 작성하였습니다
IUPUI, Team S2-G2, Baechle Fall 2018 IUPUI, Team S2-G2, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S2G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 21
전체 시간: 841
