주요 콘텐츠로 건너뛰기
Dell Latitude E6540 Battery Replacement
필요한 것
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: 1 단계, 이미지 1/2 Dell Latitude E6540 Battery Replacement, Hibernate your laptop: 1 단계, 이미지 2/2
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: 2 단계, 이미지 1/2 Dell Latitude E6540 Battery Replacement, Unlock the battery: 2 단계, 이미지 2/2
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: 3 단계, 이미지 1/3 Dell Latitude E6540 Battery Replacement, Remove the old battery: 3 단계, 이미지 2/3 Dell Latitude E6540 Battery Replacement, Remove the old battery: 3 단계, 이미지 3/3
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install the new battery: 4 단계, 이미지 1/3 Dell Latitude E6540 Battery Replacement, Install the new battery: 4 단계, 이미지 2/3 Dell Latitude E6540 Battery Replacement, Install the new battery: 4 단계, 이미지 3/3
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: 5 단계, 이미지 1/1
    • Turn the computer on and plug the charger in.
결승점
다른 7명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,851 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,534개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 36
전체 시간: 8,149
