주요 콘텐츠로 건너뛰기
Dell Latitude E7250 CMOS Replacement
필요한 것
  1. Dell Latitude E7250 CMOS Replacement, removing the battery: 1 단계, 이미지 2개 중 1개 Dell Latitude E7250 CMOS Replacement, removing the battery: 1 단계, 이미지 2개 중 2개
    • Slide the release latch to unlock the battery
    • Lift the battery from the computer.
  2. Dell Latitude E7250 CMOS Replacement, Remove base cover: 2 단계, 이미지 2개 중 1개 Dell Latitude E7250 CMOS Replacement, Remove base cover: 2 단계, 이미지 2개 중 2개
    • Remove the screws that secure the base cover to the computer
    • Slide the base cover
  3. Dell Latitude E7250 CMOS Replacement, Removing the Keyboard Trim: 3 단계, 이미지 2개 중 1개 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard Trim: 3 단계, 이미지 2개 중 2개
    • Using a plastic scribe, pry the edges of keyboard trim to release it from the computer
    • Lift up to remove the keyboard trim from the computer.
  4. Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: 4 단계, 이미지 3개 중 1개 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: 4 단계, 이미지 3개 중 2개 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: 4 단계, 이미지 3개 중 3개
    • Lift the battery bay that secures the keyboard to the computer
    • Lift the latch that secure the keyboard cable to the computer
    • Disconnect the keyboard cable the computer
  5. Dell Latitude E7250 CMOS Replacement, Removing the SSD Card: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the SSD card to the computer
    • Lift and remove the SSD card from the computer
  6. Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: 6 단계, 이미지 3개 중 1개 Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: 6 단계, 이미지 3개 중 2개 Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: 6 단계, 이미지 3개 중 3개
    • Remove the screws that secure the palmrest assembly and flip the computer.
    • Perform the following steps as shown in the illustration: a. Lift the latch that secures the keyboard and touch cable to the computer [1]. b. Disconnect the keyboard and touch cable to the computer [2]. c. Remove the screws that secure the palmrest assembly to the computer [3].
    • Perform the following steps as shown in the illustration: a. Pry the edges of the palmrest assembly [1]. b. Lift the palmrest assembly from the computer [2].
  7. Dell Latitude E7250 CMOS Replacement, Removing/ Installing the Coin-Cell Battery: 7 단계, 이미지 1개 중 1개
    • Perform the following steps as shown in the illustration: a. Disconnect the coin-cell cable from the computer [1]. b. Lift the coin-cell battery from the computer [2]
    • Installing the Coin-Cell Battery 1. Place the Coin-cell battery on the computer. 2. Connect the coin-cell battery cable to the computer
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jordon Dozier
회원 가입일: 02/10/21
1,663 평판
안내서 12개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 927
