주요 콘텐츠로 건너뛰기
Dell Latitude E7250 RAM Replacement
필요한 것
  1. Dell Latitude E7250 RAM Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude E7250 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: 2 단계, 이미지 1/3 Dell Latitude E7250 RAM Replacement, RAM: 2 단계, 이미지 2/3 Dell Latitude E7250 RAM Replacement, RAM: 2 단계, 이미지 3/3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: 3 단계, 이미지 1/3 Dell Latitude E7250 RAM Replacement: 3 단계, 이미지 2/3 Dell Latitude E7250 RAM Replacement: 3 단계, 이미지 3/3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Liliana Mendoza
회원 가입일: 09/25/17
156 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 50
전체 시간: 4,865
