주요 콘텐츠로 건너뛰기
Dell Latitude E7250 SSD Replacement
필요한 것
  1. Dell Latitude E7250 SSD Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude E7250 SSD Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: 2 단계, 이미지 1/3 Dell Latitude E7250 SSD Replacement, SSD: 2 단계, 이미지 2/3 Dell Latitude E7250 SSD Replacement, SSD: 2 단계, 이미지 3/3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: 3 단계, 이미지 1/3 Dell Latitude E7250 SSD Replacement: 3 단계, 이미지 2/3 Dell Latitude E7250 SSD Replacement: 3 단계, 이미지 3/3
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Robert Townsend
회원 가입일: 09/25/17
357 평판
안내서 2개 작성하였습니다
댓글 한 개
Thanks a lot for this !
viperx007 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 128
전체 시간: 10,592
