주요 콘텐츠로 건너뛰기
Dell Latitude E7270 Motherboard Removal
필요한 것
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: 1 단계, 이미지 1/1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: 2 단계, 이미지 1/1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: 3 단계, 이미지 1/1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: 4 단계, 이미지 1/1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: 5 단계, 이미지 1/1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: 6 단계, 이미지 1/1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: 7 단계, 이미지 1/3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: 7 단계, 이미지 2/3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: 7 단계, 이미지 3/3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: 8 단계, 이미지 1/1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: 9 단계, 이미지 1/1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 10 단계, 이미지 1/3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 10 단계, 이미지 2/3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: 11 단계, 이미지 1/1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Clement
회원 가입일: 01/14/20
756 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 2,696
