주요 콘텐츠로 건너뛰기
Dell Latitude E7270 RAM Replacement
필요한 것
  1. Dell Latitude E7270 RAM Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 RAM Replacement: 2 단계, 이미지 1/1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 RAM Replacement: 3 단계, 이미지 1/1
    • Lift and remove the panel.
  4. Dell Latitude E7270 RAM Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 RAM Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 RAM Replacement: 6 단계, 이미지 1/1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 RAM Replacement, RAM: 7 단계, 이미지 1/1
    • Locate the 2 RAM modules above where the battery would be.
    • The two blue RAM modules used in the photo may vary in color from your device.
  8. Dell Latitude E7270 RAM Replacement: 8 단계, 이미지 1/1
    • While the RAM is still seated, push the silvered clips either side of each stick outwards. There should be some obvious upward movement from each stick.
  9. Dell Latitude E7270 RAM Replacement: 9 단계, 이미지 1/1
    • Firmly grab each RAM with your fingers and pull them away from you to remove them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Clement
회원 가입일: 01/14/20
756 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 842
