주요 콘텐츠로 건너뛰기
Dell Latitude E7270 Solid State Drive Replacement
필요한 것
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Solid State Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Solid State Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude E7270 Solid State Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: 7 단계, 이미지 1개 중 1개
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the SSD of its socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Clement
회원 가입일: 01/14/20
776 평판
안내서 6개를 작성함
1가이드 댓글
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 67
전체 시간: 5,066
