주요 콘텐츠로 건너뛰기
Dell Latitude E7440 Battery Replacement
필요한 것
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: 1 단계, 이미지 1/1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: 2 단계, 이미지 1/3 Dell Latitude E7440 Battery Replacement, Release the battery: 2 단계, 이미지 2/3 Dell Latitude E7440 Battery Replacement, Release the battery: 2 단계, 이미지 3/3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: 3 단계, 이미지 1/1
    • Lift the battery by the top, away from the laptop body.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Akash Kedia
회원 가입일: 01/24/19
1,397 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - 답글
Any recommended site to buy original battery?
Razin Ahmed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 71
전체 시간: 5,313
