주요 콘텐츠로 건너뛰기
Dell Latitude E7440 CMOS Battery Replacement
필요한 것
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: 1 단계, 이미지 1/1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 1/3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 2/3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 2 단계, 이미지 3/3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: 3 단계, 이미지 1/1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 1/2 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 2/2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: 5 단계, 이미지 1/2 Dell Latitude E7440 CMOS Battery Replacement: 5 단계, 이미지 2/2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 1/3 Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 2/3 Dell Latitude E7440 CMOS Battery Replacement: 6 단계, 이미지 3/3
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: 7 단계, 이미지 1/1
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Akash Kedia
회원 가입일: 01/24/19
1,397 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 2개
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - 답글
@jess13j, battery is a CR2032 coin cell.
senzog - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 98
전체 시간: 13,314
